Author [ES] [MY] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Oil change  (Read 1776 times)
0 Members and 2 Guests are viewing this topic.
Offline J Kevin
  • Bike: 2017 Multistrada
  • Town / City: Foresthill Ca
Oil change
« on: August 16, 2019, 04:28:10 PM »
I am ready to do my 2nd oil change. I just noticed in the manual that I need to clean the mesh filter assembly. I didn't see this on the first oil change and I didn't see a screen filter. Can anyone tell me what I am missing or where I should look?  :002:
Offline ducati_al
  • Bike: MTS 950 - Red
  • Town / City: Crowborough
Re: Oil change
« Reply #1 on: August 17, 2019, 10:44:42 AM »
Hi Kevin - I'm not sure TBH - oil & oil filter would be what I'd change, although as I'm still in warranty the dealer has been doing that for me.  I see what you mean looking at the manual, there is a separate line from "Change engine oil and filter" where it says "Clean the engine oil mesh filter assembly".  It can't be hard, if only we knew where it was.... :174:
Offline ducati_al
Re: Oil change
« Reply #2 on: August 17, 2019, 10:51:31 AM »
Think I might have it......found mention of it under the Multistrada 1200 forum - on the 1200 at least, the mesh filter assembly is located next to the main oil drain plug.  Here is a link to the relevant forum page http://www.mts1200.info.gridhosted.co.uk/index.php?threads/engine-oil-change.154/ - it's about half way down if you follow the procedure for oil change.
Offline J Kevin
Re: Oil change
« Reply #3 on: August 17, 2019, 07:21:13 PM »
ducati_al, I just removed the skid plate, and can not see anything that would be connected to a scree. On my 71 500 r/t. the screen is part of the drain plug. I will get the 950 up on the lift in the next couple of days (waiting for my oil shipment from amazon). I will also call the service manager and see if I can get any answer from her. I will let you know if I find out anything.
Offline ducati_al
Re: Oil change
« Reply #4 on: August 18, 2019, 08:45:28 PM »
OK - be interesting to know what you find.  If only there was a workshop manual readily available.... :232:
Offline lather
  • Town / City: St. Francisville
Re: Oil change
« Reply #5 on: August 18, 2019, 11:18:55 PM »
I have not done the mesh filter as I decided to let the dealer do it but I have a copy of the 2016 Muti 1200 Enduro shop manual that shows it. THe 950 is probably the same. I will post screen captures.
Hope this helps.
We're lost but we're making great time!
Offline Grahew
  • Town / City: PERSHORE
Re: Oil change
« Reply #6 on: August 19, 2019, 07:49:48 PM »
The engine on the 950 is a different configuration to the 1200. The filter is mounted on the front  with the filter plug hole on the side with a small drain plug under weath, they are two different engines with the 950 coming directly from the super mortard :821:
Offline lather
Re: Oil change
« Reply #7 on: August 20, 2019, 12:26:40 AM »
Thanks for clearing that up. It is a shame we cannot get a service manual for the 950 Multi. I will look for one for the Supermotard.
Offline Conman
  • Town / City: Stockport
Re: Oil change
« Reply #8 on: August 20, 2019, 08:54:25 AM »
The mesh filter is on the side of the engine as Grahew says. This is a really good clip showing it.
I think there may be another filter underneath the engine close to the drain plug. I've seen some older descriptions where they take this out, but Ducati seem to have a policy of moving the filter around depending on the engine size  :015: I can't see why they would need two so perhaps it's not on the MTS950 engine. However there is what looks like another plug type affair  :027:
« Last Edit: August 20, 2019, 08:56:09 AM by Conman »
Anything more than two wheels is unnecessary.
Offline Bordenrider
  • Town / City: Borden, Saskatchewan
  • Country: ca
Re: Oil change
« Reply #9 on: September 19, 2019, 11:00:28 AM »
The Multi 950 has the same engine as the Hyper 939.  Service manual can be downloaded here:
https://workshop-ducati.blogspot.com/2017/01/ducati-hyperstrada-2016-repair-workshop.html
Oil change from monster 821 should be the same.
On Youtube do a search for "Ducati Monster 821 | Oil Change"
All 3 plugs torque at 42N/M (min 38 max 46), Oil Filter 11 N/m, Mesh filter hand-tight only.
« Last Edit: September 19, 2019, 11:31:03 AM by Bordenrider »
