Author Topic: Rear Brake Pedal awkward  (Read 12084 times)
  • Offline metalguru   gb
    • MTS 950 Member  ‐    11
    Offline metalguru
    • Town / City: STONE
    on: August 30, 2019, 05:33:37 pm
    Hi guys, does anyone else out there find the rear brake pedal difficult to use as it seems tucked under the clutch?  Is there an alternative available?  I don't get my knee down so don't mind if it sticks out a bit more.   :001:
    • MTS 950 Master  ‐    883
    Re: Rear Brake Pedal awkward
    Reply #1 on: August 30, 2019, 08:22:50 pm
    I think you can get an extention part for it.
    Look at a Web page called Altrider
    Last Edit: August 30, 2019, 08:42:27 pm by thenozzle
  • Offline Mrchow   us
    Offline Mrchow
    • Town / City: New york
    Reply #2 on: August 30, 2019, 10:47:36 pm
    + 1 on altrider pedal enlarger first thing I did
  • Offline ChrisS   ch
    Offline ChrisS
    Reply #3 on: August 31, 2019, 11:51:06 am
    I fitted the Altrider pedal enlarged too. Completely transformed the rear brake for me.  Much easier to use.
    Offline metalguru
    Reply #4 on: September 04, 2019, 06:05:13 pm
    Actually found this on eBay, £12.67 with free postage
    https://www.ebay.co.uk/itm/Motorcycle-Silver-Aluminum-Alloy-Widened-Brake-Pedal-Foot-Pedal-Stainless-Screws/323809945261?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
    Fitted it today and it works well, had to replace two of the bolts for ones slightly longer and made sure to use a thread locker.
    What's provided:
    After:
    Last Edit: September 04, 2019, 06:15:04 pm by metalguru
    • MTS 950 Pro  ‐    254
    Reply #5 on: September 04, 2019, 06:28:04 pm
    metalguru, looks fantastic! I think I will give a shot with this! I want to order sw-motech enduro/touring pegs and for sure it will work together nicely:)
  • Offline Daveontheedge   ca
    • MTS 950 Member  ‐    40
    • Bike: 2018 R1200RS
    • Town / City: Vancouver
    Reply #6 on: September 05, 2019, 08:04:36 am
    *Originally Posted by Julian [+]
    Have you looked at Pivot Pegz? I had a set on my last bike and they were fantastic. Very wide platform that actually pivots a few degrees front and back giving you maximum contact with the pegs at all time. Aggressive tread if you off road or you can add a rubber top that zip ties on for street riding.
    I'm not a big fan of this brake pedal either so I'll be looking into the Altrider option myself.
    Did you guys go with the enlarger only or with the riser as well? I don't do a lot of off road, maybe a bit of gravel every now and then so not a ton of standing up other than stretching.
    Last Edit: September 05, 2019, 08:11:01 am by Daveontheedge
  • Offline ChrisS   ch
    Offline ChrisS
    Reply #7 on: September 05, 2019, 08:29:07 am
    I didn't bother with the riser - same reasons as you mention. Prior to fitting the gadget it was difficult to put enough pressure on the pedal to hold the bike on a hill. No problem doing that now.
    • MTS 950 Pro  ‐    254
    Reply #8 on: September 05, 2019, 08:32:52 am
    Looks very good the Pivot Pegz also, but I like much more the ones from sw-motech because I want to used them for touring especially, one or two times off road, where I can pull down the rubber inserts.
    Reply #9 on: September 06, 2019, 08:47:11 am
    I personally don’t feel the need for this mod as I’m well used to the stock pedal & it just becomes second nature to use
