Author Topic: Worrisome wear  (Read 3340 times)
  • Offline Desmofonso   es
    • MTS 950 Member  ‐    17
    Offline Desmofonso
    • Country: es
    Worrisome wear
    on: October 09, 2019, 06:00:40 pm
    Hi there friends
    Checking my bike I found some attrition points.
    1.- On the oil hose, from the radiator to the engine's bottom. The pipe touches the water radiator and abrades the plastic cover, even it scratches the metal web  :012: This was solved reorienting the pipes in the engine side, to get some extra milimeters and avoid this issue. I softened the water radiator edge too.
    2.- On the exhaust valve steel wire. The frame touches the wire, and abrades the wire's cover  :182: Not solved yet (just put a plastic tape) but in my opinion, bending the support spring to divert the wire from the frame will be enough.
    Please, see the pictures attached.
  • Offline Goldstar   gb
    • MTS 950 Pro  ‐    145
    Offline Goldstar
    • Bike: MTS 950 & 797+
    • Town / City: Norfolk
    Re: Worrisome wear
    Reply #1 on: October 09, 2019, 06:16:23 pm
    I had this problem soon after I got the bike, pipe replaced under warranty....
    https://www.multistrada950.com/index.php/topic,329.msg2042.html#msg2042
    Re: Worrisome wear
    Reply #2 on: October 09, 2019, 10:43:33 pm
    The other wear point to look out for is the front brake hoses touching the front mudguard didn’t rubbing through the plastic outer sleeve. They are braided steel underneath so no real damage will be done. I simply wrapped some black plastic insulating tape around the hoses at these points.
    Re: Worrisome wear
    Reply #3 on: October 14, 2019, 02:24:22 pm
    The exhaust flapper valve control wire did snap on mine. Never found a reason but this is a good candidate.
    Offline Desmofonso
    • Country: es
    Re: Worrisome wear
    Reply #4 on: March 23, 2020, 03:08:11 pm
    *Originally Posted by neilb [+]
    An alternative coating for the brake hoses, and many other appications. I use the Kintsglue from Loctite. This protuct has a chewing gum-like consistency when open the envelope. When it dries it's like hard rubber, but flexible.
