Author Topic: The damnable Battery Charger socket...  (Read 13178 times)
  • Offline Bikerhands   gb
    Offline Bikerhands
    • Town / City: Consett
    on: November 12, 2019, 05:59:47 pm
    I apologise upfront for the stupidity of this question but...wanting to plug my Optimate in with the correct plug, I cannot for the life of me work out how to get the end cap off the
    Ducati plug thingy!! It may be to do with 2 issues. Big fat fingers attached to big hands and nerve damage in the tips of said fingers. However, I think operator stupidity is more likely.
    Before my temper frays and I start throwing things, scaring the dogs and causing neighbours to check my sanity, am I missing something obvious? Do I need to press/pull/slide
    something?!! It can't surely be this difficult to get a cap off the end of a rubbery plug thing!!!   :440:
    Oh, am amused by people calling the 950 Mutley. In the past, all my bikes have been named, Beemers usually have ended up with Brunhilda, Bertha or Gertha. Triumph's ended up as
    Trumper (bad choice in retrospect), Thumper and Kylie. Have no idea why. Harleys were Shaker and 'over priced pile of poo'. Guess the Multi could be a Mutley but that suggests a bit
    of a sniggering dog...
  • Offline ChrisS   ch
    Offline ChrisS
    Re: The damnable Battery Charger socket...
    Reply #1 on: November 13, 2019, 12:58:01 pm
    Mine's a 2018 model and simply pulls off with no issues.  It's a push fit just like the cover on the Optimate cable thing that plugs into it. Unless they've changed out then it should be pretty simple to pull off
  • Offline ZiggyCol   gb
    • MTS 950 Pro  ‐    197
    Offline ZiggyCol
    • Bike: MTS 950 (Red)
    • Town / City: Harrogate
    Reply #2 on: November 13, 2019, 06:36:01 pm
    Bikerhands
    I assume your Ducati socket is the same as mine (arrowed below) in which case the cap simply pulls off. (The small lead shown is to connect to my CTEK charger).
    Life is not a rehearsal . . .
    Offline Bikerhands
    Reply #3 on: November 18, 2019, 10:17:36 am
    Thanks for the pic and the comment but, no, mine doesn't have one. And while messing about with it, managed to make the bike fall over! Luckily no damage as it rested on a big fibreglass roof box but it took me and a neighbour to get it back on its wheels. I have dropped a R1200 BMW (not GS) while cleaning it a while back and I got that back on its feet easily. Must've been the lower centre of gravity...still slapping myself. Oh well, guess I'll have to buy one of these connectors which go through the 12v socket
    • MTS 950 Pro  ‐    197
    Offline ZiggyCol
    Reply #4 on: November 18, 2019, 10:34:38 am
    Lucky with the drop! Don't understand why the same bike should have different fixtures but there we are - I'm sure you'll figure a solution.
    Reply #5 on: November 18, 2019, 03:45:42 pm
    *Originally Posted by Bikerhands [+]
    Why don’t you simply connect an Optimate power lead to the battery terminals? A five minute job. Also, the dash 12V socket is switched, so you won’t have any joy plugging into that; don’t know about the under-seat one as I’ve never used it.
    Reply #6 on: November 18, 2019, 07:24:04 pm
    *Originally Posted by ZiggyCol [+]
    Bikerhands
    That plug looks aftermarket to me as I don't have that plug either & I use the genuine Ducati battery maintainer that plugs into the 2 pin socket on the side of the ECU
    • MTS 950 Pro  ‐    197
    Offline ZiggyCol
    Reply #7 on: November 19, 2019, 05:06:00 pm
    Well the bike was bought new from a Ducati dealer and that's how it came, with the arrowed socket already wired ready to receive a charger cable. Who knows ????
    • MTS 950 Pro  ‐    378
    Reply #8 on: November 20, 2019, 07:53:34 pm
    Here's a link to the photo I have put on the Gallery section. https://cdn.img.multistrada950.com/caiD.jpg
    It shows where I had discreetly positioned my optimate lead. It's zip tied behind the RHS pillion peg frame and wired direct to the battery under the main seat.
    I hope this helps. No longer own the 950.
    • #9
    Offline Bikerhands
    Reply #9 on: November 21, 2019, 03:30:37 pm
    Thanks all for the comments/advise. Have now found a local expert (Mark at VTS) who has proved to me that there is no connector!! He was a Ducati service technician so can be trusted!
    Found one of the straight to battery leads on eBay, so my worries will soon be over!
