Author Topic: Head lights out  (Read 934 times)
  • Offline Ducati et moi   us
    • MTS 950 Member  ‐    13
    • Bike: 950 S Ducati
    • Town / City: Pasadena, CA
    Head lights out
    on: June 09, 2020, 10:38:02 pm
    Hi guys, bonjour a tous,
    This morning on a two hours ride the dash board on my 2019 Multistrada 950 s I noticed on the dashboard the blue head high beams light was flashing as well as the green low beam light and a small warning (basic error) sign on the top left corner of the dash. Of course I figured it has to do with the lights so I stopped and sure enough no lights at all (Low or high Beam) Getting home I checked the fuse for lights under the driver seat and no the fuse is OK.
    As any of you experienced that and how did you fix it? Of course I called my Ducati dealer and they can't see me until 25 June (today is the 8th) NOT GOOD.
    I hope all of you are ok.
    Si vous êtes français et ne lisaient pas l'anglais, mon problème est que ce matin mes lumières se sont éteintes complètement  et le signe bleu sur le tableau de bord (Plein phare) ainsi que le vert (code) se sont mis a clignoter? Si vous savez pourquoi vous êtes les bienvenus  de me dire ce qui ce passe...Merci et bonne balade. P.S j'ai une Multistrada 2019 et 950 S
  • Offline mcinlb   gb
    • MTS 950 Member  ‐    81
    Offline mcinlb
    • Bike: 950 Multistrada
    • Town / City: Falkirk
    Re: Head lights out
    Reply #1 on: June 10, 2020, 08:59:28 am
    Sorry, don't know what , if not the fuse. I also have a 950S, doesn't sound good. :021: :021:
    I would possible check the ground connections if they are all out. The supplies all come via the instrument panel..
    Hope you get it fixed..
    Last Edit: June 10, 2020, 09:07:23 am by mcinlb
