Author Topic: New LED indicator lights.  (Read 1321 times)
  • Offline Funkster   gb
    • MTS 950 Member  ‐    34
    Offline Funkster
    • Bike: Multi 950 2018
    on: October 13, 2020, 11:51:23 am
    Hi, just fitted new LED sequential indicators and waiting for the connector fly leads to arrive. Not the Ducati lights.
    Question is do I need to fit the resistors as well? The resistors that came with the lights are a bit too big for the space. Standard tail fittings.
    I had a look for the flasher relay but it looks to be part of the dash. Seen that on the 1200 you can change settings to led lights. Not found this on the 950 yet.
    Pics below.
    Last Edit: October 13, 2020, 12:10:50 pm by Funkster
    • MTS 950 Pro  ‐    135
    Re: New LED indicator lights.
    Reply #1 on: October 13, 2020, 05:48:17 pm
    Probably one of those that you will have to connect up and see. I put the LED indicators from the Panigale on my 950 and they just worked so hopefully you will have the same result.
    Offline Funkster
    Reply #2 on: October 15, 2020, 03:48:09 am
    Connected up without the resistors and they worked...just got to tidy up the wiring and put it all back to gether. 😎
