Author Topic: Alu rack  (Read 4886 times)
  • Offline Juani   gb
    • MTS 950 Member  ‐    18
    Offline Juani
    • Town / City: Tenby
    Alu rack
    on: April 14, 2021, 09:56:17 pm
    Can anyone confirm that the pillion grab handle frame is different on a 2020 S  from 2017 base model and that my Alu rack won’t fit on a new S model?
    Many thanks in advance
  • Offline ajy1w   us
    • MTS 950 Pro  ‐    249
    Offline ajy1w
    • Bike: MTS950 / HDFXR
    • Town / City: Maplewood
    Re: Alu rack
    Reply #1 on: May 10, 2021, 03:02:20 pm
    Hi Juani,
    What I can tell you is I use have the Hepco Becker easy rack basically same as Alurack, same support mounting system.
    After 9000 miles my Grab Rail has cracked.  I noticed when cleaning the bike the arms that support the the rack that holds top case had cracked on both sides.  When I removed the mounting system I discovered that this also created a crack in grab rail right under the rubber gourmet on the center of the grab rail.  The grab rail part is all one piece that is the whole box under the pillion seat.
    $489.00 USD from Ducati does not include installation and looks like the power outlets would need to be disconnected to replace the part.
    You should check under your mount.
    Life behind bars enjoy the ride
  • Offline Juani   gb
    Offline Juani
    Re: Alu rack
    Reply #2 on: May 10, 2021, 03:46:39 pm
    All good with mine, although I never put anything heavy in top box when using it, it’s more of a somewhere to lock helmet away when stopping for a coffee 👍
