Author Topic: Added "Dark" theme...  (Read 1321 times)
  • Offline MattR   gb
    • Forum Help and Support
    • MTS 950 Member  ‐    98
    Offline MattR
    on: May 03, 2021, 04:01:09 pm
    Some people prefer a dark background when browsing, especially when using a mobile, consequently as part of the forum updates I've now added a "Dark theme...
    There are several ways of switching....
    1) Using Theme Select on main forum page (as per image below).
    Note that if you check the "Permanently" checkbox then it will resume the new theme when you log back in again. Otherwise it will "forget" once you logout. Even if you do select "Permanently" you can still reverse it again using the same procedure.
    2) Using Theme Toggle when using a Mobile
    Just click the toggle when using the forum on your phone. (it's not permanent using this method).
    3) Change the theme from within your Profile area
    Go to the "Look and Layout" area in your Profile:
    Then click on the text as in the image below:
    Thats it ...  :028:
     :821:
