Author Givi EA118 tankbag fitted  (Read 1406 times)
  • Offline Desmo Dronic   scotland
    • MTS 950 Member  ‐    15
    • Bike: 950-S
    • Town / City: Loch Lomond
    on: June 21, 2021, 06:00:48 pm
    Just fitted my new Givi EA118 tankbag and BF11 Tanklock ring today.
    Took about 5 mins from start to finish. Only tools needed were a 4mm and 3mm hex driver.
    I'm a bit concerned about the unsupported part of the base rubbing on the tank paintwork so I might have to get some kind of tank protector pads.
    Unfortunately the annoying E5/E10 label and the M+S tyre label don't do anything to help the situation so will be binned.
    Any tips for removing them safely and cleanly ?
    So far I'm impressed with the EA118 tankbag as it seems a well made bit of kit and it fixes securely to the bike.
    Not so sure about the Security Belt as it's a bit of a faff to use and it's too short to use as a shoulder strap.
    DD
    Last Edit: June 21, 2021, 06:06:29 pm by Desmo Dronic
  • Offline simonkraushaar   nl
    • MTS 950 Member  ‐    59
    • Bike: 950s Touring
    • Town / City: Amsterdam
    Re: Givi EA118 tankbag fitted
    Reply #1 on: June 21, 2021, 06:11:50 pm
    labels just peel off, especially in warmer weather.  Any residue can be removed with kitchen roll and olive oil (yes, i know it sounds strange!)  WD40 also works i think
    • Bike: 950-S
    Reply #2 on: June 21, 2021, 09:35:03 pm
    I think I'll try using olive oil. (It is an Italian bike after all.)   :002:
    DD
    • Bike: Versys 1000
    Reply #3 on: June 21, 2021, 11:52:11 pm
    If the label wont peel easily, or if it leaves residue, get a tin of 'zippo' style lighter fluid and make sure you have lots of kitchen or workshop paper to catch the excess.
    Pour a little onto the label and rub it in with your finger, pour a little more and rub it in, pretty quickly the label and the glue will start disintegrating. Keep wiping the excess and spillage outside the label with the kitchen paper to keep it under control.
    Reply #4 on: June 22, 2021, 11:50:18 am
    Top tip - Use a hairdryer to warm up the labels before attempting to remove them... they should then peel off cleanly and nicely
    Reply #5 on: June 23, 2021, 04:29:25 pm
    The magic WD40 works really well at removing sticky residue.
  • Offline flyfifer   scotland
    Offline flyfifer
    • Town / City: UK
    Reply #6 on: April 09, 2022, 05:11:32 pm
    Desmo Dronic,
    Does the design of the 118 let you have the tank lock ring right up at the front of the bag ?
    I am just wondering if the ignition is not obscured.
    • Bike: 950-S
    Reply #7 on: April 11, 2022, 07:08:33 pm
    Hi Flyfifer,
    The EA118 has 3 possible positions for fitting the mounting ring on the base of the tankbag, middle, 10mm forwards or 10mm rearwards.
    I used the middle position but since my bike is the -S model with keyless ignition it's just not an issue.
    If you look at my side view photographs you'll see that there is plenty of room to use a regular ignition key but there's no way that you'd be able to see it whilst riding the bike.
    Hope this helps,
    DD
    Offline flyfifer
    • Town / City: UK
    Reply #8 on: April 11, 2022, 08:30:18 pm
    I realised after posing my question that you were keyless !
    I played around with my 15litre xstream today but with an ignition key it is a non starter -- even with the mounting plate full forward i
    Being able to have a choice of tankbag has to be a good reason to get an S with keyless ignition ! Bugger !
  • Offline Beano   gb
    • MTS 950 Member  ‐    12
    Offline Beano
    • Town / City: Coventry
    Reply #9 on: April 13, 2022, 12:18:17 pm
    As opposed to an unsightly tank protector pad(s) have a look at Easi-Grip film. You can buy it in various sizes and it forms to the shape of your bodywork as you apply it. Same as 3M Ventureshield. Itís clear and almost invisible once applied. Iíve also applied it on the leading edges of the fairing to protect against stone chips as well as where my knees rub the tank (all on my outgoing Tracer 9)
