Author Topic: Heated Grips not working  (Read 1110 times)
  • Offline douglas851   ie
    Offline douglas851
    • Bike: 888
    • Town / City: Co Clare
    on: December 18, 2021, 01:59:44 pm
    I am trying to fix the non-working heated grips on my Multistrada.
    They are OEM Ducati and are switched via the menu on the dash. You can get to the "H.G. Off" setting on the menu but when I push the Indicator button to turn them on it disappears and goes to the Riding Mode setting.
    I have checked the both plugs going to the grips and can get a resistance reading of approx 7 ohms for both, so it seems that the heating elements are fine.
    Where else to check?
  • Offline ChrisS   ch
    Offline ChrisS
    Re: Heated Grips not working
    Reply #1 on: December 19, 2021, 05:56:44 pm
    The problem may simply be that the manual is wrong.  To select the heart setting you have to press the menu button up and hold for a few seconds,  the you'll see HG LO and can scroll through the three heat levels,  you the press the indicator button for a few seconds to confirm chosen level. The manual leaves out the first step with the menu button,  at least it does in the English version.
    Offline douglas851
    • Bike: 888
    Reply #2 on: December 20, 2021, 09:29:59 am
    Thanks for the explanation. It all works fine now.
    As you say the English version of the manual is not clear on how to do it.
