Forum Rules
Forum Help
28 Jun 22, 07:42 am
Main Multistrada 950 and V2 Boards
Maintenance and Servicing
chain & rear sprocket aligment
28 Jun 22, 07:42 am
Pages:
chain & rear sprocket aligment (Read 271 times)
vklee
MTS 950 Junior ‐
vklee
MTS 950 Junior
Bike: 950 (2017)
April 11, 2022, 05:32:47 am
Hi All,
I'm a new rider, got my multi950 (2017) year ago, bike running 9K++ km.
Anyone have this problem? Is this abnormal or just my over worried.
I tried to adjust with alignment tool, but chain still not centred in the rear sprocket.
Sign of scrubbing on the inner side of the chain, although always lube after every ride.
Hope someone can advise here, can I add few washers between the sprocket to offset the gap?
Thanks all in advance.
Logged
DesmoD
MTS 950 Member ‐
14
DesmoD
MTS 950 Member
Re: chain & rear sprocket aligment
Reply #1 on:
April 11, 2022, 12:21:33 pm
What chain alignment tool are you using? It would be very interesting to see how its results compare to your adjustment indicators or even a ruler measuring off a reference point.
If I was concerned about misalignment causing wear, the rear sprocket inside face would be worth inspecting to see if you are getting wear.
But the fact it isn't central wouldn't cause me much concern unless I could see wear. One only factor is if you have already had a chain and sprocket change that has caused an offset due to aftermarket parts etc.
I think the reality is the chain will not float centrally on either sprocket and you just need to check for wear. I think it would take a significantly noticeable misalignment to wear it out and you would see this on adjustment indicators.
Logged
Pages:
Puig Dark Sports Screen for sale
Parts, Accessories & Clothing For Sale
Wassers
June 26, 2022, 10:51:03 pm
Pannier gone missing
BabyD
June 26, 2022, 10:39:58 pm
Soon to be 950s owner
Burnsey
June 26, 2022, 12:06:32 pm
S W Motech Pro Rack
flyfifer
June 26, 2022, 10:58:26 am
New model heated grips on 950S...?
razu
June 26, 2022, 09:46:31 am
Delivery time
IanTed
June 26, 2022, 08:12:07 am
Cold weather hand guard covers 950s
gmf1
June 24, 2022, 10:51:06 pm
Has anyone pulled the Alternator/Stator/Generator Cover?
flyfifer
June 24, 2022, 08:11:50 pm
