Forum Rules
Forum Help
28 Jun 22, 07:44 am
Main Multistrada 950 and V2 Boards
Maintenance and Servicing
Has anyone pulled the Alternator/Stator/Generator Cover?
28 Jun 22, 07:44 am
Pages:
Has anyone pulled the Alternator/Stator/Generator Cover? (Read 245 times)
nasher75
MTS 950 Member ‐
26
nasher75
MTS 950 Member
Bike: 20 950 S
Town / City: Los Gatos
June 01, 2022, 04:15:00 pm
I stupidly stripped one of the bolts that attach the alternator cover to the engine case and had a couple questions... I will need to install a helicoil to repair these threads and it will require removing the cover to drill out the hole to a larger size for helicoil insert installation.
Have you ever pulled this cover off?
Will this cover have oil behind it and require draining engine oil before removal?
How critical is this to repair, right away? If it is not a critical oil sealing area, I'm assuming I do not need to repair right away...
Logged
Hunt Hard, Kill Swiftly, Waste Nothing, Offer No Apologies...
Paul_Smith
MTS 950 Pro ‐
110
Paul_Smith
MTS 950 Pro
Bike: Versys 1000
Town / City: Roscommon
Re: Has anyone pulled the Alternator/Stator/Generator Cover?
Reply #1 on:
June 02, 2022, 12:46:18 am
Here is the parts diagram.
https://www.bike-parts-ducati.com/ducati-motorcycle/Multistrada/2017/Multistrada_950/Multistrada-950/ALTERNATOR-COVER/299/15/0/299
While it looks like there is no oil behind the alternator cover, you will have to go through the water pump to get to it. Which bolt did you strip? That will determine how urgent the repair is.
Logged
nasher75
MTS 950 Member ‐
26
nasher75
MTS 950 Member
Bike: 20 950 S
Reply #2 on:
June 07, 2022, 05:57:12 am
Well, turns out I was lucky or unlucky depending on how you look at it. I'm running the Zieger Skid plate and it uses bolts for the Clutch and Alternator covers for bracket mounting. Turns out, the bolts they give you are too short. The factory bolts are actually longer and grab more threads. Luckily, it only stripped because it only had 3-4 threads engaged. The longer bolt was able to thread and come to full torque.
Logged
flyfifer
MTS 950 Member ‐
59
flyfifer
MTS 950 Member
Town / City: UK
Reply #3 on:
June 24, 2022, 08:11:50 pm
Begs the question - Why did you fit bolts that were shorter than the original !!??
Logged
Pages:
Puig Dark Sports Screen for sale
Parts, Accessories & Clothing For Sale
Wassers
June 26, 2022, 10:51:03 pm
Pannier gone missing
BabyD
June 26, 2022, 10:39:58 pm
Soon to be 950s owner
Burnsey
June 26, 2022, 12:06:32 pm
S W Motech Pro Rack
flyfifer
June 26, 2022, 10:58:26 am
New model heated grips on 950S...?
razu
June 26, 2022, 09:46:31 am
Delivery time
IanTed
June 26, 2022, 08:12:07 am
Cold weather hand guard covers 950s
gmf1
June 24, 2022, 10:51:06 pm
flyfifer
