Author Topic: DeCat installation and Inspection  (Read 1286 times)
  • Offline ducatista34   tr
    Offline ducatista34
    • Bike: 950S
    • Town / City: Istanbul
    • Country: tr
    on: July 21, 2022, 10:21:25 pm
    Hi everyone
    Quick question about Leo Vince DeCat pipe. If the pipe is installed (it is listed is not Homologated) what happens in vehicle inspections, specifically in Germany? Does the vehicle fail inspection with the pipe ? Do I need to install the original cat pipe for the inspection, then remove it afterwards?
    Response will be appreciated.
    • MTS 950 Pro  ‐    156
    • Bike: Versys 1000
    Re: DeCat installation and Inspection
    Reply #1 on: July 22, 2022, 11:51:10 am
    It has not been through homologation. That doesn't mean it would fail the test, it just means that if it does fail the test, it is your problem not theirs.
    Offline ducatista34
    • Bike: 950S
    • Country: tr
    Reply #2 on: August 10, 2022, 01:40:48 pm
    thanks
  • Offline karmarider   in
    • MTS 950 Member  ‐    31
    Offline karmarider
    • Bike: 2021 MTS 950 S
    • Town / City: Chandigarh
    • Country: in
    Reply #3 on: August 15, 2022, 11:08:21 am
    What is the general wisdom on fitting a mid pipe, does that require remapping? I have a Termignoni slip-on can and am considering the Leo Vince mid pipe to go with it. The local Ducati dealership says that a remap is a must as otherwise the engine runs on a lean AFR while it needs a richer AFR to deal with the free flow exhaust setup.
    Any thoughts?
    Offline ducatista34
    • Bike: 950S
    • Country: tr
    Reply #4 on: August 15, 2022, 02:53:50 pm
    My previous Multi 1000DS, did not need any remapping. From what I've read, this does not need any remapping at all, but some advise to do so, the advantages are loosing weight, better looks, better sound, and simply why not?
    • MTS 950 Pro  ‐    156
    • Bike: Versys 1000
    Reply #5 on: August 15, 2022, 03:59:08 pm
    The bike will run perfectly well without a remap. It will run better still with one. Your money, your bike, your choice.
    Offline karmarider
    • Country: in
    Reply #6 on: August 15, 2022, 06:34:19 pm
    Thank you for responding, gentlemen. I haven’t been able to track down anyone offering a flash for our bike. The only option seems to be to go for a fuel controller, like Rapid Bike.
