Author Front suspension...again...:-)  (Read 11194 times)
  • Offline Goldstar   gb
    Offline Goldstar
    • Bike: MTS 950 & 797+
    • Town / City: Norfolk
    on: October 20, 2017, 03:09:40 pm
    Picked up a new MTS, the front end was very soggy even on the mildest braking...its now sorted though following advice from a guy who preps Dukes for track days..
    I wound back the compression damper (thats the flat head screw slot on the L/H strut) fully anti clockwise, 8 clicks, to note the end setting, then re-wound 8 back clockwise to original setting, plus 4 more clockwise, thats now 12 from fully anti-clockwise.
    Then added half a turn clockwise on the rebound, this the two brass hexagonal adjuster on the top of each strut...
    Front end now behaves wonderfully... :002:
    Re: Front suspension...again...:-)
    Reply #1 on: October 20, 2017, 05:04:44 pm
    Good advice thanks . I think several on the forum  have also added the 3 to 4 clicks to the standard setting on the Compression setting.
    I think the 2 hex adjusters are actually the Pre-load  (not rebound)  - which would make sense to prevent the front end diving
    Offline Goldstar
    Reply #2 on: October 20, 2017, 09:45:27 pm
    Thanks Buzzard, you are absolutely correct, it is pre-load....apologies for any confusion caused...
  • Offline Philo_84   au
    Offline Philo_84
    • Bike: Multi 950
    • Town / City: Melbourne
    Reply #3 on: November 23, 2017, 03:13:10 am
    After reading comments from various publications I have tried with two clicks of compression and rebound but found it a bit harsh, so tried with only one click and I think it is a good compromise...
  • Offline Christy   gb
    • MTS 950 Member  ‐    39
    Offline Christy
    • Town / City: Hull
    Reply #4 on: December 21, 2017, 10:49:17 am
    Looking at the number of posts on this, we could do with a definitive guide with pics and make it a sticky on the website.
  • Offline paul annetts   es
    • Country: es
    • Town / City: malaga
    Reply #5 on: August 17, 2018, 01:58:04 pm
    This is my first time on a forum so bear with me. Got the 950 and have read the other comments about front forksetup. Can I assume the the adjustments  (compression and rebound) are carried out on both front forks?
    Reply #6 on: August 17, 2018, 07:39:54 pm
    Compression is set via the screw adjuster on the left hand fork, rebound is adjusted via the screw on the top of the right fork leg. Itís a fime art, make small adjustments only if you need it.
    • Country: es
    Reply #7 on: August 18, 2018, 07:38:19 am
    Thanks for that!! :152:
  • Offline lowprofile   ph
    • MTS 950 Member  ‐    25
    Offline lowprofile
    • Country: ph
    • Bike: MTS950s, M1200S
    • Town / City: Paranaque
    Reply #8 on: August 21, 2018, 09:35:41 am
    Im used to sport suspensions so here is my take.
    At 170 pounds rider weight without gear, i cranked up the preload all the way.
    Then I adjusted the compression to about 2 to 3 before fully closed
    The rebound I forgot but its about 1 second to return
    Now I ride it like a sport bike :)
    ymmv
    • Country: es
    Reply #9 on: August 21, 2018, 02:28:58 pm
    Thanks. I will give that a try.
