Author Topic: WindScreen for MTS 950  (Read 16141 times)
  • Offline pmxbmega   pt
      #20
    Offline pmxbmega
    • Town / City: Lisbon
    Re: WindScreen for MTS 950
    Reply #20 on: September 13, 2018, 05:27:24 pm
    I have decided,
    I will go to a short racing one, WRS with 38cm tall, why? because this summer I suffer a lot with the heat  :008: :008:, and I'll be more pleased with the air on my chest than over the helmet, as well the wind noise is ok under the 160kmh.
    so I'll use the original in the winter and the shorter in the summer  :018:
    that all folks ;)
    ... just f##king ride :P
    Reply #21 on: September 14, 2018, 07:15:24 am
    I'm the same. Will be putting my original screen back on soon for the winter commutes into London.
    Was only 6 degrees when I rode in yesterday morning. Felt a bit nippy after all this lovely weather.
      #22
    Reply #22 on: September 14, 2018, 08:13:57 am
    I tried my standard windscreen at its lowest setting last night and the wind buffeting over 60mph was horrendous. It felt like it was going to pull my helmet off. So it's back to mid way for commuting and fully up with vario for serious distances. I might be tempted to go for a bigger touring screen if they weren't so damned ugly  :004:
      #23
    Reply #23 on: October 06, 2018, 07:31:36 pm
    Has anyone tried these screen spacers ?????
    eBay item 283194506210
  • Offline Dodger68   gb
    • MTS 950 Member  ‐    17
      #24
    Offline Dodger68
    • Bike: multistrada 950
    Reply #24 on: October 07, 2018, 07:02:58 pm
    Hi All
    I have a set of those spacers fitted with a mra screen . Its the best I have come up with so far , you seem to get clean airflow  around your helmet (oh er mrs) using this setup. I tried the mra without the spacers and it didn't work nearly aswell. I don't think you will get any better as the screen is very close relatively speaking . You will need to modify the spacers slightly for the mra but a standard screen will fit straight away . The spacers are made to sit in the indentations around the hole in the screen . The mra does not have them so you just need to cut them down slightly .This is not too hard as they are plastic. I use a Arai tour x helmet . I hope that helps.
    Cheers
      #25
    Reply #25 on: October 12, 2018, 09:49:50 am
    I received these in the post......
     :435:  what am I suppose to do with them........
      #26
    Reply #26 on: October 12, 2018, 10:43:01 am
    *Originally Posted by BabyD [+]
    Take a look at the pictures on the eBay page and Iím sure youíll suss it out from there. Surprised there are no instructions though.
  • Offline Beitsta   ie
      #27
    Offline Beitsta
    • Town / City: Cork
    Reply #27 on: October 12, 2018, 11:13:16 am
    Can't wait to see how you get on BabyD with the modification to see if it improves/eliminates the buffeting...
    Beitsta
      #28
    Reply #28 on: October 12, 2018, 03:35:54 pm
    I don't have to standard screen either I have the Givi D7406ST
      #29
    Reply #29 on: October 12, 2018, 05:10:22 pm
    This is before.....
    Notice how close to the mirror arm the Givi screen is....
    This is after spacers fitted.....
    A little more space between mirror arm & screen with spacers fitted....
    Now the screen does not fit flush with the spacers unlike the standard screen & when you tighten the bolts it has to bend the screen slightly to close the gap other than that my only other thing I noticed AND I DO NOTICE THINGS LIKE THIS the bottom of the screen isn't perfectly equal on both sides.
    AM I BEING TOO PICKY????
