Got around to installing this today. First decision was where to locate the reservoir. I didn't want it on the handlebars but wanted it neatly located but accessible to operate on the move if necessary. So decided to mount on nearside here - arrow indicates the bolt position I'll use . . .
Only it needs a longer bolt and spacer - see original and replacement . . .
Here is the reservoir mounted . . .
I wanted feeder tube routing to be as neat and secure as possible. This photo shows a channel cut into the under swingarm chain guide which provides a good method of securing . . .
Tube entry to the swingarm secured with a simple tube clip . . .
And another used under the swingarm . . .
And finnaly the dripper itself attached with a couple of cable ties . . .
All in all pleased with the result.
