Author Topic: 950 addons  (Read 2831 times)
    • MTS 950 Master  ‐    891
    950 addons
    on: February 09, 2019, 11:13:20 am
    Found this British site for multistrada
    www.iconicparts.uk
    Re: 950 addons
    Reply #1 on: February 09, 2019, 03:41:21 pm
    I’m gonna buy the water radiator cover, would get oil as well but don’t fancy taking front of bike off to fit
    Re: 950 addons
    Reply #2 on: February 09, 2019, 03:58:30 pm
    www.iconicparts.uk
    Spooky! I came across this site last night 😮
  • Offline ZiggyCol   gb
    • MTS 950 Pro  ‐    197
    Offline ZiggyCol
    • Bike: MTS 950 (Red)
    • Town / City: Harrogate
    Re: 950 addons
    Reply #3 on: February 10, 2019, 12:13:14 pm
    *Originally Posted by BabyD [+]
    It's not that difficult, you just have to research how the panels fit and take your time. I fitted Evotech covers for water and oil and didn't have any real problems.
    Life is not a rehearsal . . .
    Re: 950 addons
    Reply #4 on: February 21, 2019, 05:33:54 pm
    Fitted the water radiator guard today....
    If like me you have the genuine engine bars & extra lights, there is a lot more work involved in fitting as you need to removed both sides of the engine bars to enable you to remove the extra lights which in turn will let you angle the bracket that the lights are fixed to enough for the hooks on the top of the rad guard to hook over top of radiator, make sure to hooks are bend out enough as it will not sit flush with radiator if not.
    If you don't have to engine bars you will need to cable tie the guard in place, but with engine bars, the bottom bar holds the rad guard in place so no cable ties needed.
  • Online buzzardbilly   gb
    • MTS 950 Pro  ‐    313
    Online buzzardbilly
    Re: 950 addons
    Reply #5 on: February 21, 2019, 06:49:55 pm
    Useful info BabyD - thanks . That is what has been stopping me from fitting one as I to have the Ducati bars and lights fitted and was not sure if the guard would fit with them in place . How long did it take you in total do you think ?
    Re: 950 addons
    Reply #6 on: February 21, 2019, 08:02:15 pm
    *Originally Posted by buzzardbilly [+]
    About 1.5 HRS
    I think I was lucky as at one point I thought I would have to take both side farrings off as well to loosen the bolts where the light & engine bars attach above the radiator but mine were loose enough lift upwards
    I forgot to fit the sticky pad spacers so hopefully mine doesn't rattle, but I was not taking it all part again just for them.
    Last Edit: February 21, 2019, 08:06:13 pm by BabyD
