Author defective gearbox position sensor  (Read 3148 times)
    on: February 21, 2019, 12:21:15 am
    My 950 had been showing a flickering gear indiacter and flickering green neutral light when I shifted to neutral. Also if I put the side stand down when in neutral the engine would die, likewise it would not start with the gearbox in neutral and the sidestand down. I asked the dealer to check this when I had my 18000 mile service done earlier this month. Actual mileage was closer to 20,000.  The service department determined the gear position sensor was defective. Ducati approved a warranty replacement and they got this done in a weeks time. They also replaced a worn chain and front sprocket which I paid for.
  • Offline angamico   us
    • MTS 950 Member  ‐    54
    Offline angamico
    • Town / City: Nassau Bay / Houston
    Re: defective gearbox position sensor
    Reply #1 on: February 21, 2019, 04:55:32 am
    I have the same problem.  I am waiting on word of warranty repair after having it checked by the dealer in January.
    David
  • Offline kfchai   my
    • MTS 950 Member  ‐    12
    Offline kfchai
    • Country: my
    • Town / City: Kuantan
    Reply #2 on: June 09, 2019, 04:27:27 pm
    same with mine, mine is everytime i gearin 5th gear the gear inicator will show 5 , 4 , 3, 2, 1, N, 1.
    will your check engine light on because of this problem ?
    my cel light on , i don't know what causes, my 950 just 200miles.....
    sh#t
    Reply #3 on: June 10, 2019, 02:14:50 pm
    My check engine light did not come on when I was having the problem with the gear position sensor. And the problem only only occurred when the gearbox was in neutral.
  • Offline Desmofonso   es
    • MTS 950 Member  ‐    17
    Offline Desmofonso
    • Country: es
    Reply #4 on: June 12, 2019, 05:02:37 pm
    *Originally Posted by kfchai [+]
    sh#t
    Mine did the same. Several errors on engaged gear, and finally Chek Engine Light ON.
    The reason is the gear box sensor is conected to the CAN-Bus system. A defective sensor can cause interferences to the rest of the sensors conneted to de CAN-Bus (bad communication). Connecting the Ducati diagnose system, ECU shows failures in the front ABS sensor, BlueTooth module and of course gearbox sensor. Replacing this one, and a ECU's reset (under warranty) solves the problem.
    In other forums some Ducati owners reports this issue, about these and other models.
