Author Topic: New owner questions - Idle Speed and Lumpy Low Down  (Read 3060 times)
    • MTS 950 Pro  ‐    146
    • Bike: V2S, R9T, MT01
    on: July 15, 2019, 05:21:36 pm
    Hi there ...
    Just had my 2017 950 for a few days and couple of questions to ask ...
    Engine idle speed seems high ... although not easy to read that low down the rev range I'm guessing maybe 1300-1400 rpm ... does this seem right?
    Pick up from low down the rev range can be jerky .. obviously feathering the clutch hides this.
    I was using sport and switched to touring and it seems fairly similar in both.
    I think this "a characteristic" of the big twin.
    I'm also getting occasional false neutrals - but again I think this is "normal". (My first bike was a Ducati Scrambler a couple of years ago and this also had false neutrals)
    • MTS 950 Pro  ‐    317
    Re: New owner questions - Idle Speed and Lumpy Low Down
    Reply #1 on: July 15, 2019, 07:18:44 pm
    Ian, Your idle does seem a  little high to me  - once warm I think it should be nearer to 1k
    The big V's are a bit lumpy at the lower revs - 3k and below - by comparison to say a four cylinder bike and you do need to work the gearbox a bit at the slower speeds
    The false neutrals should go away in time - it is a feature of the square cut gears and they need bedding in
    Enjoy your 950 - it is a great bike . Occasionally I think about a change but can't think of anything that would match it and look so good as well (apart from a 950S maybe !)
    • MTS 950 Pro  ‐    146
    Reply #2 on: July 15, 2019, 09:01:26 pm
    Thanks for replying ... pretty much what I expected to hear....
    The idle does seem to change when warmed up to being slightly lower.
    I'm likely going to ask Ducati about this ... my first step with a bike new to me is to check if all recall work has been done and this is an easy way for me to ask them to check the idle at the same time.
    Reply #3 on: July 15, 2019, 10:19:49 pm
    Mine idles at around 1300 to 1350, it's not a problem. If you start the bike rolling above 5mph (out of gear) revs pick up to over 1600 automatically.
    One thing I had to adjust to is the Ducati needs higher revs than just about any other bike I've owned. It's the only bike I've ever ridden where I have to drop in to first gear in slow traffic or tight turns. If the revs drop too low it does growl and become lumpy. My son had the same problem and really didn't like the bike until I explained if you're dropping below 3000 rpm you need to change down. It feels like you're riding it hard if you're coming from say a BMW but the bike thrives on it   :305:
    Reply #4 on: July 16, 2019, 05:46:33 pm
     :400: Ian_H glad to see another 950 in my area
    • MTS 950 Pro  ‐    146
    Reply #5 on: July 16, 2019, 08:29:50 pm
    See you at On Yer Bike no doubt!
    • MTS 950 Pro  ‐    146
    Reply #6 on: July 16, 2019, 08:36:56 pm
    *Originally Posted by Conman [+]
    I've got an R9T 1200 as well ... which seems to happy to pull away in 1st, 2nd or 3rd.... but red lines at about 8000 or something - so Yes ,, adapting to giving the Ducati more beans.
